03-31-2009 01:29 PM - edited 03-06-2019 04:55 AM
Facing issue in Cisco 6509 switch with the port speed and duplex servers are not negotiating on 1 Gbps but it is working on 100 Mbps.
We have tried by making combination of Auto / 1000 Full Duplex on both switch and server side but still it is not working.
Logs are attached
03-31-2009 01:45 PM
Rakesh,
Are all servers connecting with 100Mbps?
You did hard code on both ends. Still not working. It sounds a bit crazy but what is the media type you are using? Cat5?
Toshi
03-31-2009 02:01 PM
Check the wiring , you need 4 good pairs all the way thru to the servers as gig uses all 8 wires to run. 1 bad wire or pair will not allow gig service.
03-31-2009 02:11 PM
In addition to glen check whether the server NIC drivers are upto date
Have seem some problems due to them in the past
Narayan
03-31-2009 03:09 PM
Are you sure the server's NIC will go 1Gb???
Can you post what is the NIC's model number?
