CallerID Not Functioning
Mar 31st, 2009
Hi there.  I have recently set up and configured a UC520 with two lines hooked into fxo 0/1/0 and fxo 0/1/1 and it currently won't display Caller ID.  System was set up with CCA 1.9 with 7.0.2 software.  As it stands, we have 4 CP7970 phones.  I have connected a standard phone up to the FXS ports and dialed in and can see caller id so I know that the signal is coming through.  I'm curious where I can look to change the configuration for this.  System is located in Michigan with Verizon as the provider.  Any ideas would be appreciated.  Thank you.
matthewe1 Thu, 04/02/2009 - 05:14
Thank you for the links.  I will check them out and see what I can take from them.  I appreciate the response.
