CUCME Version 7.0(1) GUI Problem
cristian.munoz
Level 4
Level 4
Hi, I can't access to CUCME by GUI. When I put the username and the pass, then, the web page get to blank.
The commands web admin system name admin password cisco and ip http server are run.
Please verify that you have the following files on your flash:
Admin-user.html
Admin_user.js
dom.js
ephone_admin.html
normal_user.html
normal_user.js
Telephony_service.html
xml.template
xml-test.html
These are all of the files necessary to enable full GUI functionality.
Hope that helped, if so please rate.
9 Replies 9
Do you have "ip http path flash:" configured?
Dear Kenneth...Yes
Hi to access the GUI and allow the admin to add remove DNs from web interface:
ip http server
ip http path flash:
telephony-service
dn-webedit
time-webedit
Hope this help
David
Cool, I'm going to re-configure and I will show you the result.
Hi..fail. :(. I think that upgrading will be fine.
Hi David
I upgraded to 124-22.T (Cisco 2811), but i still can't access to GUI. I put the user and passw and then it show me the page in blank. Pls.,see the command
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
telephony-service
em logout 0:0 0:0 0:0
max-ephones 42
max-dn 80
ip source-address 10.175.206.1 port 2000
system message CME
user-locale ES
network-locale ES
time-zone 18
time-format 24
date-format dd-mm-yy
voicemail 3120
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Mar 31 2009 15:20:31
I don't know what happens
Admin-user.html
Admin_user.js
dom.js
ephone_admin.html
normal_user.html
normal_user.js
xml.template
xml-test.html
Dear Kenneth, the problem is solved.
Thanks a lot!!
Hi All,
i have CME version 7.1 with IOS 12.4(24T1)and i experienced the same problem with the GUI interface. i found that the problem came from copying the GUI files using a flash reader, when i uploaded the files using the archive command and used the command ip http server path flash: ,the GUI worked fine but after a restart.
