Autotunnel in single route processor scenario
Answered Question
Mar 31st, 2009
Just to be totally sure. Autotunnel is incompatible with single route processor systems, e.g. an 7600 with only one supervisor installed, as it would be configures with stateful switchover (SSO) by default.
Correct Answer by Laurent Aubert about 8 years 4 weeks ago
It's supported as any other feature. What is not supported is autotunnel is not SSO aware so during a switchover, your tunnel will flap and you will loose traffic.
Laurent.
Overall Rating: 5 (1 ratings)
Correct Answer
Laurent Aubert Wed, 04/01/2009 - 17:33
  • Cisco Employee,
Laurent.
PerseusDK Wed, 04/01/2009 - 23:39
Hi Laurent
Thanks for your reply. This is why Netpro is great... Just to clarify the manuals :)
Lars
