Help with IPSEC configuration between Two Sites
Mar 31st, 2009
Hi All,
I'm trying to configure a IPSEC VPN between two sites but can't get it to work.
Network Topolgy
[LAN1: 192.168.199.0/24] -> [Cisco 2600: ADSL Connection] -> Internet <- [Cisco 7200] <- [LAN2: 192.168.198.0/24]
Note: I've simulated the LAN at each end by using a loopback interface.
Cisco 2600
crypto isakmp policy 1
authentication pre-share
crypto isakmp key MY-KEY address 210.15.x.x
crypto ipsec transform-set TRANSFORM-SET esp-des esp-sha-hmac
crypto map IPSEC-VPN 1 ipsec-isakmp
set peer 210.15.x.x
set transform-set TRANSFORM-SET
match address 101
interface Loopback1
description Test loopback for IPSec VPN
ip address 192.168.199.1 255.255.255.0
interface ATM0/1
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password AAABBBCCCDDDEEE
access-list 101 permit ip 192.168.199.0 0.0.0.255 192.168.198.0 0.0.0.255
Cisco 7200
crypto isakmp key MY-KEY address 202.134.x.x
set peer 202.134.x.x
match address 101
interface Loopback1
ip address 192.168.198.1 255.255.255.0
interface GigabitEthernet0/0.502
description Test Vlan 502
encapsulation dot1Q 502
ip address 210.15.x.x 255.255.255.0
access-list 101 permit ip 192.168.198.0 0.0.0.255 192.168.199.0 0.0.0.255
Troubleshooting
***** I can ping the public IP's from each router, so there's no problems with connectivity.
***** show crypto map
2600#sh crypto map
Crypto Map "IPSEC-VPN" 1 ipsec-isakmp
Peer = 210.15.x.x
Extended IP access list 101
Current peer: 210.15.x.x
Security association lifetime: 4608000 kilobytes/3600 seconds
PFS (Y/N): N
Transform sets={
TRANSFORM-SET,
Interfaces using crypto map IPSEC-VPN:
ATM0/1
Dialer0
Virtual-Access2
7600#sh crypto map
Peer = 202.134.x.x
Current peer: 202.134.x.x
PFS (Y/N): N
Transform sets={
TRANSFORM-SET,
***** A "sh crypto isakmp sa" and "how crypto engine connections active" shows no active connections.
***** I've tried "debug crypto ipsec" and "debug crypto isakmp" but nothing's coming up.
What's wrong with my config???
Do I need to turn on NAT. I thought the private IP's would be tunneled across the IPSEC tunnel???
Do I need to set up static routes for each remote LAN to go via the peer IP?
Eg: 2600#ip route 192.168.198.0 255.255.255.0 210.15.x.x
My config is pretty much the same as most IPSEC tutorials I've read???
Any help would be greatly appreciated.
Thanks.
Andy
Overall Rating: 5 (2 ratings)
Richard Burts Tue, 03/31/2009 - 20:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andy
My first suggestion would be to verify whether you have connectivity for traffic sourced from one loopback and destination in the other loopback. If you do an extended ping and the extended ping specifies the source as one loopback and the destination as the other loopback what are the results.
Rick
asaykao73 Tue, 03/31/2009 - 20:14
Hi Rick,
I can't reach either loopbacks using an extended ping.
2600#ping
Protocol [ip]:
Target IP address: 192.168.198.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: loopback1
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.198.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Same result on the 7600.
I didn't think these loopbacks would be reachable unless they traverse the IPSEC tunnel.
Thanks.
Andy
Richard Burts Wed, 04/01/2009 - 10:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Andy
In looking at the configs again I notice that the 2600 has ip nat outside configured on the dialer interface. Is it possible that the 2600 is translating the traffic going out that should be going through the VPN? Can you supply the detail from the 2600 about how it is doing address translation?
Rick
John Blakley Wed, 04/01/2009 - 10:42
  • Purple, 4500 points or more
Andy,
Rick's correct. If you're not excluding this network from the VPN, it will get translated.
In your nat statement, try denying the traffic sourced from the local router to the remote router on both sides. That should bring your tunnels up and be able to get traffic across them.
So on your 7600:
ip nat insi sour list 105 inter dial1 exten
access-list 105 deny ip 192.168.198.0 0.0.0.255 192.168.199.0 0.0.0.255
access-list 105 permit ip 192.168.198.0 0.0.0.255 any
The 2600 would have the same thing:
access-list 105 deny ip 192.168.199.0 0.0.0.255 192.168.198.0 0.0.0.255
access-list 105 permit ip 192.168.199.0 0.0.0.255 any
I haven't seen your nat config, so I'm just using the above for reference.
*** Edit ***
You'll only need to add the nat exclusion on the 7200 if you're using nat on that device. (I'm assuming that you are.)
HTH,
John
asaykao73 Wed, 04/01/2009 - 17:03
Hi John,
Thanks for your reply.
I have added a 'deny' statement to the access list on the 2600 , but still no go.
There's no nat being done on the 7200.
See above reply to Rick for more details.
Cheers.
Andy
asaykao73 Wed, 04/01/2009 - 17:00
Hi Rick,
The 2600 is actually my home router and I have a few 192.168.x.x networks that I've vlan off. I've natted them through like so.
Eg:
interface Loopback1
interface Ethernet0/0
no ip address
full-duplex
interface Ethernet0/0.9
description Server VLAN
encapsulation dot1Q 9
ip helper-address 192.168.1.254
ip nat inside
ip flow ingress
interface Ethernet0/0.10
description Management VLAN
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip flow ingress
interface Ethernet0/0.11
description Admin VLAN
encapsulation dot1Q 11
ip address 192.168.11.1 255.255.255.0
ip nat inside
ip flow ingress
access-list 1 deny 192.168.199.0 0.0.0.255
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
Thinking about what you said, I added a 'deny' statement to access-list 1 to prevent the loopback ip from being translated.
access-list 1 permit 192.168.0.0 0.0.255.255
I can see matches now when I do an extended ping, but still can't reach the other end.
router1-greenvale#ping
Protocol [ip]:
Repeat count [5]:
Extended commands [n]: y
Source address or interface: loopback1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Packet sent with a source address of 192.168.199.1
router1-greenvale#sh access
router1-greenvale#sh access-l
router1-greenvale#sh access-lists 1
Standard IP access list 1
10 deny 192.168.199.0, wildcard bits 0.0.0.255 (5 matches)
20 permit 192.168.0.0, wildcard bits 0.0.255.255 (13 matches)
Not sure what I'm missing ??? Do you need a route to get to the other end (from network 192.168.199.0/24 to 192.168.198.0/24) or is it tunneled through the IPSEC tunnel using the public ips (202.134.236.132 to 210.15.210.83)???
2600#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C 192.168.12.0/24 is directly connected, Ethernet0/0.12
C 192.168.13.0/24 is directly connected, Ethernet0/0.13
C 192.168.14.0/24 is directly connected, Ethernet0/0.14
C 192.168.15.0/24 is directly connected, Ethernet0/0.15
202.10.80.0/32 is subnetted, 1 subnets
C 202.10.80.1 is directly connected, Dialer0
202.134.236.0/32 is subnetted, 1 subnets
C 202.134.236.132 is directly connected, Dialer0
C 192.168.10.0/24 is directly connected, Ethernet0/0.10
C 192.168.11.0/24 is directly connected, Ethernet0/0.11
C 192.168.199.0/24 is directly connected, Loopback1
C 192.168.1.0/24 is directly connected, Ethernet0/0.9
S* 0.0.0.0/0 is directly connected, Dialer0
Thanks.
Andy
asaykao73 Wed, 04/01/2009 - 18:15
Hi Guys,
Thanks for all your help. I haven't been able to work it out but it may have something to do within our internal network. I tried the ipsec config on a different sub-interface on the same 7200 and it's working - but it won't work for the original sub-interface. Not to worry, I'm just happy it's working on another sub-interface and I can do further testing.
Cheers.
Andy
Richard Burts Thu, 04/02/2009 - 08:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Andy
I am glad that you got it to work. I am not sure why it will work on some subinterface on the 7200 and not work on the original subinterface. Perhaps there is some difference in connectivity between the subinterfaces or some different set of interface parameters that interact differently with VPN.
Rick
