UCCX 7.0 call redirect step to ext begin with *
Answered Question
Mar 31st, 2009
I have UCM 7.0, UCCX 7.0
I have the CTIRP set up as *XXXX so people can call direct to voicemail. That works great.
I have a script in UCCX where it does a check for agent logged in. if agents logged in = 0, then I want to send direct to their personal extension's VM box without ringing their phone.
So, the step has the extension as "*7935".
The documentation says the * and # is supported as an extension, however, debugging the script marks it as invalid.
Has anyone tried this? Got it to work?
Erin
Correct Answer by villarrealed about 8 years 3 weeks ago
Erin,
Change the parameters of the Redirect step to use the VM pilot at the destination and change the called address to the the VM box, 7935 in this example.
Overall Rating: 5 (3 ratings)
Anthony Holloway Wed, 04/01/2009 - 08:48
  • Purple, 4500 points or more
In all previous versions we have deployed a quad nine solution as dialing an * out of UCCX does not work.
So for example, in your script dial 99991234 to go direct to VM 1234.
Your 9999 pattern in CUCM would be very similar to that of your * pattern.
It goes without saying that 9999 could be anything other than * in your environment.
Correct Answer
villarrealed Wed, 04/01/2009 - 09:50
  • Bronze, 100 points or more
Erin,
