Alberto Montilla Wed, 04/01/2009 - 04:58
  • Cisco Employee,
Dear Sir;
SPA2100 is End of Life since 2006, and there is no updated firmware for this product. Its replacement product is SPA2102.
Alberto
rhoadesma Wed, 04/01/2009 - 06:30
What was version was the last firmware update?
Can it be downloaded from somewhere?
I have a spa-2100 that is in good working order and has not been updated in a long time and would like to start using it again.
Alberto Montilla Wed, 04/01/2009 - 07:08
  • Cisco Employee,
Can you send me an email to amontill at cisco.com, so that I can provide you with the firmware?
Regards;
Alberto
gehendeleiche Wed, 05/27/2009 - 04:38
Hello!
Could you please help me?
I use a cisco spa2100-ss phone adapter and it reduces my bandwidth to 10MBps. That is to say, before plugging it to my computer I had a 100MBps internet connection via LAN. Can this problem be solved somehow? Perhaps upgrading the firmware will help?
Alberto Montilla Wed, 05/27/2009 - 05:13
  • Cisco Employee,
Dear Sir;
My recommendation is that you dont plug in the PC to the SPA2100, but directly to the network router. SPA2100 router speed is 10 Mbps.
Alberto
gehendeleiche Wed, 05/27/2009 - 07:09
Alberto, you know, I'm connected to the internet via LAN and my computer has got only one Ethernet port, so there is no other way to establish the internet connection apart from plugging in the LAN cable into phone adapter and consequent plugging in that adapter to the computer.
So as far as I've got no router is there any way of increasing the speed of the connection between the spa-2100 adapter and the PC?
Patrick Born Wed, 05/27/2009 - 12:09
  • Cisco Employee,
There is no way to increase the SPA2100's interface beyond its physical limitation of 10MB/s.
The suggestion is to deploy the SPA2100 as a LAN appliance by connecting it to a LAN switch. I've attached a diagram.
Patrick
freeman-a Fri, 06/05/2009 - 09:33
>Hi freeman-a,
>There is no way to break into a SP locked device. There are no backdoors. The device is useless to you at this time.
>Regards,
>Patrick
Dear Patrick:
thank you for answering.
however, there are several proceedures listed on various places on the net regarding a firmware upgrade that is aborted in process (perhaps that is not the best description) that will clear out any passwords.
also, what are the jumpers for? there is one three pin installed and one two pin not installed.
where can schematics for this device be obtained?
Regards, freeman-a
freeman-a Sat, 06/06/2009 - 19:13
>Hi freeman-a,
>You're out of luck. The device is secure and does not provide any backdoors.
>Regards,
>Patrick
Dear Patrick:
that is NOT true. I UNLOCKED my spa-2100. why would you say such a thing? i now have admin, two line, and user access to my device.
why are schematics not available anywhere? the device is out of production and obviously SOMEONE has them.
for anyone who needs to unlock one of these or any in the Sipura/Linksys family, just email me. i have several solutions.
freeman-a
duplicate of https://www.myciscocommunity.com/message/8020
Related Content
