Excessive alert problem in LMS
Mar 31st, 2009
Cisco LMS Trap :-
00000S4 ; 10.10.10.1 ; Thu 26-Mar-2009 10:15:53 IST ; Critical ; SystemHardware ; Active
ALERT ID = 00000S4
TIME = Thu 26-Mar-2009 10:15:53 IST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 10.10.10.1
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = MEM-10.10.10.1/1 [Processor]:InsufficientFreeMemory; 172.20.47.3 [10.10.10.1]:Unresponsive;
CUSTOMER IDENTIFICATION =
we are getting above message continiously, while checking that particular device everything seems to be fine, plse suggest.
Vaibhav
MICHEL.HEGERAAT Wed, 04/01/2009 - 05:43
You may wish to provide a show tech of the device so that people may see what is the problem.
DFM uses a fixed threshold for free memory, so maybe you should put it unmanaged for this device if no solution can be found
How did you establish that everything is fine on the device?
Cheers,
Michel
