Warning message
Jon Marshall Wed, 04/01/2009 - 00:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
JD
The native vlan on a trunk port is the vlan that does not have an 802.1q tag. So multiple vlans can go across an 802.1q trunk port and the switch distinguishes between the vlans by the 802.1q vlan tag attached to the frames. The native vlan, vlan 1 by default, does not have an 802.1q tag.
The native vlan is there for backward compatability with switches that do not understand 802.1q tags. Cisco recommend either
1) tag all vlans including the native vlan
OR
2) change the native vlan to something other than vlan 1. The vlan you choose does not have to any ports allocated to it and does not need to have a L3 SVI. The command to change the native vlan on a trunk port is
switchport trunk native vlan
Jon
jagdev.dhaliwal Wed, 04/01/2009 - 00:38
Hi Jon,
Thanks for your help, if i have 2 vlans vlan 10 and 20 and one of them is using for IP Phone (vlan 10) and other is for PCs (vlan 20),
1) I want to connect a IP phone on a switch which i have configured as Trunk port as IP phones can strip the Vlan information from the frames
2) Further from that IP phone i want to give the connection to the PC in Vlan 20
for this I want to make the Vlan 20 as the native vlan for the Switch port.
3)is it possible ? and if i have more vlan than these two will the 802.1q tag will help to communicate with the other switches over the trunkports
regards
JD
Leo Laohoo Wed, 04/01/2009 - 14:14
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Try this:
interface
switchport mode access
switchport access vlan 20
switchport voice vlan 10
interface
switchport trunk native vlan 20
switchport trunk allowed vlan 10,20
switchport trunk encap dot
switchport mode trunk
Hope this works.
