Lms Master slave Config
networking11
Hi all,
i can configure one of my Server as Master and the other i could not as
slave even though i m giving the hostname of
Master, connectivity is there between that two servers,
MICHEL.HEGERAAT
Are you talking about single sign on or DCR master slave?
Anyway did you exchange certificates?
Common Services -> Server -> Security Multi-Server Trust Management -> Peer Server Certificate Setup
The machines can't both be called ciscoworks, even if the domain is different.
Show us your errors
Cheers,
Michel
hi michel
i m talking of Single signon only and the main issue is that the secondary server is not accepting the Master server name_ its saying not dns resolvable
That is required.
Have you tried adding both machines to DNS?
Or add an entry to both machines host files?
Cheers,
Michel
