cisco 3825 with NME-16ES-1G card
Answered Question
Apr 1st, 2009
I have got a cisco 3825 with a NME-16ES-1G module in it. I would like to set up a trunk link between the ISR router and the EtherSwitch Service Module. Is it possible?
Actually, I can not find the command switchport under the logical interface GigaEthernet 1/0 of the router ISR.
Best Regards,
Nicolas
Correct Answer by Edison Ortiz about 7 years 12 months ago
You need to create subinterfaces and assign a 802.1q Vlan ID to it.
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_b1.html#wp1020413
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
nviturat20 Wed, 04/01/2009 - 09:51
Thanks a lot, it works fine now with your solution.
Best regards,
Nicolas
