My Problem: Cisco Anyconnect Client with IOS SSL
Apr 1st, 2009
Hi Team,
I am trying to setup the Cisco IOS SSL to support Anyconnect client.
Much as I have entered all the required commands, the configuration doesn't work. My IOS is (C2800NM-ADVIPSERVICESK9-M), Version 12.4(22)T.
I would appreciate if any in this team with experience setting up anyconnect with IOS can draw my attention to any caveats.
I have selected the necessary portion of my router config for your review, if necessary.
Many thanks.
aaa new-model
aaa authentication login VPN local
aaa authorization network VPN local
crypto pki trustpoint TP-self-signed-2613188008
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2613188008
revocation-check none
rsakeypair TP-self-signed-2613188008
username remote secret 5 $1$86qN$CJ2uc1l7PYy7a5sNMrPK2/
ip local pool WEBVPN 192.168.250.11 192.168.250.111
webvpn gateway SSL
hostname CIS-EDGE1
ip address 80.87.77.18 port 443
http-redirect port 80
ssl encryption 3des-sha1 aes-sha1
ssl trustpoint TP-self-signed-2613188008
inservice
webvpn install svc flash:/webvpn/svc_1.pkg sequence 1
webvpn install svc flash:/webvpn/svc_2.pkg sequence 2
webvpn install svc flash:/webvpn/svc_3.pkg sequence 3
webvpn context SSL
ssl authenticate verify all
policy group SSL
functions svc-enabled
svc address-pool "WEBVPN"
svc default-domain "cisghana.com"
svc keep-client-installed
svc dpd-interval gateway 30
svc keepalive 300
svc split dns "cisghana.com"
svc split include 192.168.1.0 255.255.255.0
svc split include 192.168.3.0 255.255.255.0
svc split include 192.168.4.0 255.255.255.0
svc split include 192.168.21.0 255.255.255.0
svc dns-server primary 192.168.21.17
svc dns-server secondary 192.168.21.18
default-group-policy SSL
aaa authentication list VPN
aaa authorization list VPN
gateway SSL domain cisghana.com
logging enable
inservice
interface Loopback1
description For SSL VPN Use
ip address 192.168.250.250 255.255.255.0
interface GigabitEthernet0/0.80
encapsulation dot1Q 80
ip address 80.87.77.18 255.255.255.248
ip access-group OUTSIDE in //this acl permits ports 80 and 443 to the interface
no ip unreachables
ip nat outside
ip inspect CBAC out
ip virtual-reassembly
pedrulesall Wed, 04/01/2009 - 13:49
what does not work, specifically? what errors are you seeing? what client are you testing, win-mac-linux?
did you try without the ACL and the NAT?
felixnkansah Wed, 04/01/2009 - 18:22
Thanks Pedrulesall,
I am testing the Win client.
When I direct my browser to the outside interface of my router (https://80.87.77.18), it only warns me of an unknown certificate, and when I agree to proceed, nothing appears in my browser or I get 'the webpage cannot be found' error depending on the browser in use.
If I access using http, the redirect to https works fine but nothing appears in my browser.
I receive no errors besides the certificate warnings, for which I always proceed affirmatively.
I have also manually installed the anyconnect client on my Vista laptop for testing. When I connect using this client, it only prompts me of an unknown certificate. After accepting to continue, nothing more happens. It remains 'Contacting 80.87.77.18' forever.
I get a similar outcome even when the ACL is removed.
I hope the information provided above is sufficient. Thanks in advance.
