QOS on 3560 12.2(35)
Apr 1st, 2009
I'm trying to configure qos for the first time.
My configuration is as follows:
mls qos
access-list 100 permit udp any any range 16384 32767
class-map match-any rtp-stream
match access-group 100
Policy-map voice
class rtp-stream
set dscp ef
interface fa0/41
service-policy input voice
#show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
The issue is that I don't think it's working.When I issue a show access-list 100 there are no hits. Although there are phones on this port, making calls.
Does anyone know where I have gone wrong please?
bigcappa1 Wed, 04/01/2009 - 14:22
You need a bit more config. But I do remember that certain IOS images had a bug where the QOS policy worked but the stats did no increment. If you want to prove it works use a sniffer sucha as wireshark, set up a span session and check that you can see the DSCP value
The sort of config you can have as based on the QoS SRND for the 3560 could be
mls qos
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos map policed-dscp 0 24 to 8
class-map VVLAN-VOICE
match access-group name VOICE
match access-group name SIGNALING
class-map VVLAN-ANY
match access-group name VOICE-ANY
ip access-list extended VOICE
permit udp any range 16384 32767
ip access-list extended SIGNALING
permit tcp any range 2000 2002
ip access-list extended VOICE-ANY
permit ip any
policy-map IPPHONE
set ip dscp 46
police 128000 8000 exceed-action drop
set ip dscp 24
police 32000 8000 exceed-action policed-dscp-transmit
set ip dscp 0
class class-default
set ip dscp 0
police 5000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0/1
switchport mode access
switchport access vlan XXX
switchport voice vlan YYY
service-policy input IPPHONE
spanning-tree portfast
Data Traffic will just be treated as normal. The first part of the policy map permits only one voice call and remarks it ef, the second part remark the call control CS3 and the third part reduces any other voice traffic to scavanger value along with the default class which is the data
Hope this helps, will see ig I can find the bug id
