Giuseppe Larosa Wed, 04/01/2009 - 05:26
  • Hall of Fame,
    Founding Member
Hello Carl,
it is 15 seconds timer used two times.
by the way for the other thread:
this 15 seconds accomodates for
7 switch hops with an hello interval of two seconds:
15 = 7*2 + 1
So in legacy 802.1D if the diameter is increased over 7 hops the timer has to be changed accordingly.
the forward timer must be greater then the time it takes a message to travel on the whole tree
Hope to help
Giuseppe
carl_townshend Wed, 04/01/2009 - 07:14
so are we talking about the listening and learning timers? if so, when you change the forward delay to 20 secs, would this be 20 for each ?
also when the bpdu is sent from the root, the other switches forward this on, so it will get forwarded every 2 secs passed on from the switch before?
also am i right in saying it is different in RSTP, as every switch generates its own BPDU ?
cheers
Carl
Giuseppe Larosa Wed, 04/01/2009 - 07:54
  • Hall of Fame,
    Founding Member
Hello Carl,
your understanding is correct or at least I agree with you
Hope to help
Giuseppe
