guruprasadr Wed, 04/01/2009 - 04:57
HI Mohit, [Pls RATE if HELPS]
Command:
ip nbar protocol-discovery.
This will enable nbar discovery on your router.
Cisco released IOS version 12.4 (4) T. Cisco introduced much awaited Skype classification in NBAR.
NBAR configuration for Skype packets:
class-map match-any p2p
match protocol skype
policy-map Allow-p2p
class p2p
bandwidth 1024
int FastEthernet0
description WAN_INterface
service-policy input Allow-p2p
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Mohitkumarp Wed, 04/01/2009 - 05:57
thanks for the reply
Yes on Release 12.4(4)T. Cisco software supports Skype 1.0, 2.5, and 3.0
can we prioritize the Vioce traffic on Skype or its by default takes priority ?
if has to configured can you plese suggest.
