Pix 550- adding rule
Apr 1st, 2009
I have a pix 550 (6.3). I need to nat a server on my lan to the internet. The server ip 192.168.1.3 needs to be natted to 65.333.333.3 and be allowed www access only.
Need assistance with the configuration rules I need to allow on pix.
andrew.prince@m... Wed, 04/01/2009 - 06:28
try
static (inside,outside) 65.333.333.3 192.168.1.3 netmask 255.255.255.255
access-list <> permit tcp any host 65.333.333.3 eq 80
HTH>
JamesLuther Wed, 04/01/2009 - 06:35
Your IP address is invaild as the second and thrird actet exceed 255, however I'm assuming this is just an example?
Anyway, your configuration will be.
access-list in_on_outside permit tcp any host 65.333.333.3 eq 80
Assuming the IP 192.168.1.3 is behind the "inside" interface and also there is an ACL called "in_on_outside" attached to the outside interface (access-group command)
So please adjust these parameters to your config.
