802.1x Problem
Apr 1st, 2009
  • Silver, 250 points or more
Dear all,
I configured 802.1x with an 2950 and IAS ins the LAB, everything is working finde with dynamic VLAN Assignement and Guest VLAN.
I did the same with an 2948, I need to use it (mangement decission they don't want buy new one)
But there I got the error message:
A malformed RADIUS message was received from client 10.1.2.100. The data is the RADIUS message.
Can somebody helps me?
I think it must ne a setting in the IAS Radius-Client settin, or I'M wrong? I tried Cisco o. Radius Standard.
Thansk, Sebastian
mattkaya56 Wed, 04/01/2009 - 15:25
Can you post the configuration please.
When you say client do you mean PC or radius client?
I have seen this error when you use Windows client.
Sebastian Helmer Thu, 04/02/2009 - 00:34
Hi mathew,
You will attached find my config and the eventlog message of the IAS.
thanks..
Sebastian
Sebastian Helmer Fri, 04/10/2009 - 06:22
It is working now with Software 8.4. In my case i had trouble with 8.3..
Thanks all
