OC48X/POS-SR-SC
Apr 1st, 2009
  • Silver, 250 points or more
Hi guys,
I need a help with this OC48X/POS-SR-SC.I need to hear your opinion about this.
I get a really strange ping result from this card, if I ping it with the datagram size 100 and around 5000 - 11000 (it's not an exact range), it will ping perfectly, but if I use another size than the one I mentioned above, it will not ping perfectly,
It's like there is an interval that is different for each datagram size (see the output below)
What do you guys think I should do with this card? Thanks!
Router#ping i
Target IP address: 1.1.1.1
Repeat count [5]: 1500
Datagram size [100]: 1500
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 1500, 1500-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 75 percent (6/8), round-trip min/avg/max = 1/1/1 ms
Router#
Router#
Router#ping i
Repeat count [5]: 15000000000
% A decimal number between 1 and 2147483647.
Datagram size [100]: 15000
Sending 15000000, 15000-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 97 percent (719/741), round-trip min/avg/max = 1/1/4 ms
Router#
Router#
Router#
Router#ping i
Datagram size [100]: 150000
% A decimal number between 36 and 18024.
Sending 1500, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (1500/1500), round-trip min/avg/max = 1/1/4 ms
Router#
Router#p i
Repeat count [5]: 1000
Datagram size [100]: 10000
Sending 1000, 10000-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/1/4 ms
Router#
