Unknown protocol drops
Apr 1st, 2009
I'm receiving the following display on a 2811 fast ethernet connection and am not sure what it means:
FastEthernet0/0 is up, line protocol is up
20 unknown protocol drops
Overall Rating: 5 (1 ratings)
lamav Wed, 04/01/2009 - 06:25
  • Blue, 1500 points or more
I have researched this before and have never been able to get a definitive and authoritative answer, not even from Cisco TAC.
These oftentimes appear with absolutely no other indication that your network performance has been adversely effected.
If you cannot explain these errors, you can use a sniffer to indentify the unknown protocol.
HTH (It probably doesnt, but its the best I can do) :-)
Victor
Yudong Wu Wed, 04/01/2009 - 06:42
  • Gold, 750 points or more
What device is port F0/0 connected to?
Can you do a sniffer to see what packet is received when this count increments?
By the way, you can check your IOS version to see if you hit this bug CSCsx18388.
fred.gardner Wed, 04/01/2009 - 06:55
It's connected to a 2924-XL switch with
c2900xl-c3h2s-mz.120-5.WC15.bin.
Unfortunately, we don't have a sniffer.
I'm trying to use nGenius to identify the protocol. Fortunately it doesn't appear to be affecting performance...
mark.cronin Wed, 04/01/2009 - 07:17
Some times you can get dropped packets
when one device is trying to negotiate ISL or dot1q trunks and the other device does not understand the trunking protocol.
Can you ensure that both the switch and router have the ports set to not trunk
thotsaphon Wed, 04/01/2009 - 08:00
Frederick,
Well, You're gonna love MIB. (grin)
ifInUnknownProtos (.1.3.6.1.2.1.2.2.1.15)
: These are counted as unclassified errors.
The variables previously listed that do not say they appear in show interfaces are not available anywhere other than SNMP.
Please don't hesitate to check out this link.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800b69ac.shtml#QQ1
HTH,
Toshi
mark.cronin Wed, 04/01/2009 - 08:13
and also
switchport mode access
You should also move your servers / hosts
off of VLAN 1 as this is not best practice
Yudong Wu Wed, 04/01/2009 - 08:14
Hi Fred, how fast that counter increments? If you see it increase by one everytime you type "show interface", it might be related to the bug I mentioned before.
mark.cronin Wed, 04/01/2009 - 11:36
Can you show us the output from a
show interface fa0/1 switchport
On the switchport that connect to the router
fred.gardner Wed, 04/01/2009 - 11:53
UMB208R0#sh int fa0/0
Hardware is MV96340 Ethernet, address is 0013.8084.ae18 (bia 0013.8084.ae18)
Description: LAN interface at 700 E Santa Fe St Olathe
Internet address is 10.110.81.1/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 05:58:49
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 2000 bits/sec, 2 packets/sec
108257 packets input, 22583077 bytes
Received 10522 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
94558 packets output, 38512505 bytes, 0 underruns
6151 unknown protocol drops
0 lost carrier, 0 no carrier
Yudong Wu Wed, 04/01/2009 - 13:14
can you post the port configuration on 2900 switch and the output of "sh int fa x/y switchport"
fred.gardner Wed, 04/01/2009 - 13:22
I car pool, so I can't tonight, but I will tomorrow. Thanks for your input...!
Fred
fred.gardner Thu, 04/02/2009 - 05:58
Here's the router Fa0/0:
interface FastEthernet0/0
description LAN interface at 700 E Santa Fe St Olathe
ip address 192.168.231.1 255.255.255.0 secondary
ip address 10.10.46.1 255.255.255.0 secondary
ip address 10.110.81.1 255.255.255.0
ip helper-address 192.168.48.50
ip helper-address 172.17.48.50
no ip redirects
no ip unreachables
ip directed-broadcast 143
no ip proxy-arp
no ip mroute-cache
duplex full
speed 100
no mop enabled
and the switch:
interface FastEthernet0/1
description Connection to Branch Router
duplex full
speed 100
mark.cronin Thu, 04/02/2009 - 06:12
on the switch can you issue this command
show int fa 0/1 switchport
Yudong Wu Thu, 04/02/2009 - 06:18
By default, "Negotiation of Trunking" is in "ON" status. Please check the switch port to "access mode". "switch mode access".
mark.cronin Thu, 04/02/2009 - 06:24
I have not got a 2924 to test with but
I think it uses DISL rather than DTP
Yudong Wu Thu, 04/02/2009 - 06:31
Yes, you could be right.
I would like to turn off any trunk negociation.
fred.gardner Thu, 04/02/2009 - 06:35
UMB208SW11#show int fa 0/1 switchport
Switchport: Enabled
Administrative mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: isl
Operational Trunking Encapsulation: isl
Negotiation of Trunking: Disabled
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: NONE
Pruning VLANs Enabled: NONE
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Self Loopback: No
mark.cronin Thu, 04/02/2009 - 07:08
"Negotiation of Trunking: Disabled"
Well thats put a stop to that idea.
Can you put the switchport in to portfast mode.
I think you are going to need to install wireshark on a laptop and SPAN that port to look for the unknown protocol or during out of hours over a weekend look at using debug commands (ip packet detail - be carefull" on the router.
Have you got a hosts / printers on that switch with protocols like IPX DLC/LLC running?
Yudong Wu Thu, 04/02/2009 - 07:12
Agree. we have to do a sniffer to find out what the packet causes the drop if you don't know what else traffic is on that link.
