VSS Config
Apr 1st, 2009
Hi All,
I have 2 6509 (running with HSRP) which is currently in production and will be migrated to VSS. Now my question is if I convert my 2 6509 switches (switch1 and switch2) to VSS, is the configuration on both switches retain or only switch1 will retain and switch2 configuration will be remove? thanks in advance.
cheers,
reymon
Giuseppe Larosa Wed, 04/01/2009 - 12:45
  • Hall of Fame,
    Founding Member
Hello Reymon,
you can see the migration to VSS in this way.
the two boxes will become a single system so for example HSRP will not be necessary anymore.
And you will need a single ip address for each SVI vlan interface.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1054789
Hope to help
Giuseppe
Mhon Baul Wed, 04/01/2009 - 15:28
Hi Giuseppe,
Thanks for your fast reply. But I just want to confirm if my running configuration on switch2 will be remove automatically or not upon converting the switch1 and switch2 to VSS mode?..
Thanks in advance!
Cheers,
reymon
Giuseppe Larosa Thu, 04/02/2009 - 02:10
  • Hall of Fame,
    Founding Member
Hello Reymon,
When you convert two standalone switches into one VSS, all non-VSL configuration settings on the standby chassis will revert to the default configuration.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1055688
the suggested procedure is:
To convert two standalone chassis into a VSS, you perform the following major activities:
•Save the standalone configuration files.
•Configure SSO and NSF on each chassis.
•Configure each chassis as a VSS.
•Convert to virtual switching system.
•Configure the peer VSL information.
so the non-standard config of chassis2 will be removed when it finds out to be the standby of the VSS pair so after last step of the procedure reported above.
However, it is a good idea to backup existing configurations.
Hope to help
Giuseppe
Mhon Baul Wed, 04/08/2009 - 06:56
Hi Giuseppe,
Thanks for you help!
reymon
