EIGRP Routing Design Question
Apr 1st, 2009
hello all.
i inherited a large frame-relay hub and spoke network with multiple hubs and using only static routing. there are about 10 hubs, and each remote router is connected to one of these hubs, plus a backup hub (the same for every router). we would like to implement a dynamic routing protocol, and i have experience with OSPF and EIGRP. we've decided on EIGRP, but here's the issue and hence my question: the WAN addresses *within* each hub are unique, but there is overlap from one hub to another. for instance, 10.1.1.1 is a WAN interface on Hub1, Hub2, Hub3, etc. Is this a problem for EIGRP? We don't really care about learning the WAN routes, just the loopbacks on the remote routers and some static routes, both of which *are* unique, unlike the WAN addresses.
i hope i made this clear. i understand the IP overlap is not ideal, but getting those changed is an even bigger project than implementing a routing protocol, so if i can avoid it, i will. i believe EIGRP should work, but i know
OSPF won't, because it won't be able to build an accurate picture of the network with all that overlap.
thanks for your time!
lamav Wed, 04/01/2009 - 08:20
  • Blue, 1500 points or more
" for instance, 10.1.1.1 is a WAN interface on Hub1, Hub2, Hub3"
Huh? You lost me...can you elaborate further on that?
From my experience, the most efficient way to implement eigrp on a frame relay hub and spoke environment is to create point-to-point subinterfaces on the hub and spoke, with /30 subnets on the WAN links.
Victor
johndennison Wed, 04/01/2009 - 08:34
sorry, yes, that is what we have done. the problem is that 10.1.1.0/30 is used for a WAN subinterface on Hub1, Hub2, and Hub3, etc.
lamav Wed, 04/01/2009 - 08:36
Im still not understanding it.
Are you saying you have duplicate addresses on your network?? How can you assign the same subnet to 3 different serial interfaces on 3 different routers?
What am I missing?
Giuseppe Larosa Wed, 04/01/2009 - 08:44
  • Hall of Fame,
    Founding Member
Hello John,
OSPF is out of discussion.
EIGRP can support this but:
be aware that EIGRP external routes have a field that contain the EIGRP router-id.
So you need to verify that the overlapping ip address is not chosen by any router as eigrp router-id.
sh ip eigrp topology should report the router-id.
in case you can force the EIGRP router-id with eigrp router-id command
see
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfeigrp.html#wp1031884
Readdressing can be performed on a link by link basis provided that you access the remote router from the backup hub (that I hope it is fine) make your changes on the primary link and verify connectivity.
I would think of readdressing you can do it gradually over time.
Hope to help
Giuseppe
lamav Wed, 04/01/2009 - 08:58
Alrighty then....
Giuseppe is right, of course. You need to re-address your network. Honestly, I have never seen such a cockamamie set up. Why on earth would anyone deliberately assign duplicate IP addresses on their network? What could that possibly buy them?
johndennison Wed, 04/01/2009 - 09:09
Giuseppe, you've confirmed my thoughts, thank you.
FYI, we would configure the loopback on each router to be the EIGRP router-id.
