Communication Between ASA Multiple Contexts
Apr 1st, 2009
Is it possible to create the following design:
1) Multiple Contexts: Customer Internal Network; Business Partner A, Business Partner B
2) Customer net can talk to Business Partner A and B (from the inside)
3) Business Partners can't talk to each other.
If this is possible, am I gaining any additional security with using this type of context design vs. putting the business partner connectivity in DMZ interfaces and using ACLs?
Collin Clark Wed, 04/01/2009 - 13:27
  • Purple, 4500 points or more
Is there a specific reason why you would not have a single context and use a different interface for Internal, BP-A, and BP-B? It's possible to do it with multiple contexts, but I think it would be easier to do it with a single context.
Hope that helps.
captain131 Thu, 04/02/2009 - 04:51
No specific reason. My reasoning (which may be convoluted are completely off) was to give each business partner the security of being seperated by a virtual firewall from one another. It's not a strict requirement, but more of a design "thought" I had when reviewing the functionality of contexts. It sounds like I'm making it more complicated than it needs to be?
Collin Clark Thu, 04/02/2009 - 06:11
I can understand your thinking, but IMO using a single context can be just as secure. I only use multiple contexts when necessary. Also keep in mind that you can not use VPN with multiple contexts.
captain131 Thu, 04/02/2009 - 06:35
Hi Colin - Thanks for the feedback. I've had similar feedback from other engineers I spoke with offline. I will very likely go back to the single context mode. Would you suggest using DMZ's as part of the design?
Collin Clark Thu, 04/02/2009 - 06:42
Absolutely. I would create a new DMZ for each customer. Use 'inside' for your internal network and 'outside' for the public network if you have that connection.
