HWIC-4A/S async lines as console server
Apr 1st, 2009
I have a 2811 with a HWIC-A/S module installed. I want setup the HWIC module so I can use the router as a console server to the other devices in this office.
I am using CAB-SS-232MT (RS232, DTE male to Smart Serial) cables connected to a "terminal"
(RS232 to RJ45) adaptor, connected to a short (3ft) network cable, and then into to the
console ports of the other devivces (all Cisco) for the physical connection.
I have included the async router config below and the "show line" output.
My problem is that when I telnet to one of the hosts by name or port number, the communication never leaves the async router.
Am I missing some serial interface config or perhaps the line numbers are wrong?
ip host RTR-host-1 2002 192.168.254.1
ip host RTR-host-2 2003 192.168.254.1
ip host SWITCH-host-1 2004 192.168.254.1
ip host ---open--- 2005 192.168.254.1
interface Loopback0
description *** Terminal Server Interface ***
ip address 192.168.254.1 255.255.255.255
interface Serial0/0/0
physical-layer async
no ip address
encapsulation slip
interface Serial0/0/1
no ip address
encapsulation slip
interface Serial0/0/2
no ip address
encapsulation slip
interface Serial0/0/3
description *** open ***
no ip address
encapsulation slip
line 0/0/0 0/0/3
session-timeout 20
exec-timeout 0 0
no exec
transport input all
async-router#sh line
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 0 CTY - - - - - 0 0 0/0 -
1 1 AUX 115200/115200- inout - - - 0 0 32/0 -
0/0/0 2 TTY 9600/9600 - - - - - 7 0 0/0 Se0/0/0
0/0/1 3 TTY 9600/9600 - - - - - 0 0 0/0 Se0/0/1
0/0/2 4 TTY 9600/9600 - - - - - 0 0 0/0 Se0/0/2
0/0/3 5 TTY 9600/9600 - - - - - 0 0 0/0 Se0/0/3
* 514 514 VTY - - - - - 45 0 0/0 -
jawill47ec Mon, 02/01/2010 - 13:31
I wanted to inquire to see if you found a solution to your configuration.  I am in a similiar circumstance in configuring a 2811 with a hwic-16a interface.  I haven't been able to find a specific document that speaks to the async configuration of a 2811.
thanks,
james
dkinnamon Mon, 02/01/2010 - 15:05
We ended up with the same config and the issue was due to a wiring issue.  I had to send new cables to the site since I had custom made some extensions.  Check the pinouts on the cables and any extension you have in place.  I had tried straight-through and crossover cables while I was onsite, but not roll-over.
Here is the key doc from TAC
Thanks for the update – It’s very critical that last leg RJ45 is a rollover RS232 cable.
I suspected this may be the problem because the notes show the CTS, RTS, DTS, and DTR different than from a up connection.
Check out this Guide:
https://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094ce6.shtml
Search for the table “Console Connection Combination”
Notice it says RJ45 Cable to console – “Rolled” and DTE need Terminal adapter – Key being the rolled RJ45 Cable.
28xx Config below.
ip host rtr1 2002 192.168.254.1
ip host switch1 2003 192.168.254.1
ip host switch2 2004 192.168.254.1
interface Loopback0
description *** TTY to rtr1 ***
no ip address
encapsulation slip
description *** TTY to switch1 ***
no ip address
encapsulation slip
description *** TTY to switch2 ***
no ip address
encapsulation slip
no ip address
encapsulation slip
line 0/0/0 0/0/3
session-timeout 20
exec-timeout 0 0
no exec
transport input all
transport output all
sh line
      1    1 AUX 115200/115200- inout     -    -    -     0      0   80/0      -
  0/0/0    2 TTY   9600/9600  -    -      -    -    -     0   2354    0/0    Se0/0/0
  0/0/2    4 TTY   9600/9600  -    -      -    -    -     0      4    0/0    Se0/0/2
*   514  514 VTY              -    -      -    -    -    10      0    0/0      -
jawill47ec Mon, 02/01/2010 - 18:20
Excellent.  I appreciate the information and the quick response.  I tested via a single async line and it works as described.
thanks,
james
