Bulk Add Route Patterns/Route Lists
Apr 1st, 2009
I want to add some bulk route patterns. I figured how to do that easy with Export/Import. But the route lists seems a bit harder. What do I need to do to make or correct a header file? Any help?
Overall Rating: 3 (1 ratings)
bwilmoth Tue, 04/07/2009 - 06:28
  • Silver, 250 points or more
There is no tool to do this now. The only way you may be able to bulk-insert this kind of information is via AXL supported in CallManager.
