High CPU Utilization on 7200 router
Apr 1st, 2009
HI,
There is an 40 % cpu utilization in cisco 7600 router but nothing much is going with my router. No ACL,ipsec ,or bgp also i did not see any cpu hog message as well.. when i check cef drop i found that there are lot of dropps on unsupported. Could any one tell why is this drop and is this causing the cpu to go high??
Can anyone tell is causing this.
EME-01# sh cef drop
IPv4 CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 0 10 953289 0 0 0
------------------ show process cpu ------------------
CPU utilization for five seconds:31%/31%; one minute: 33%; five minutes: 33%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 5 0 0.00% 0.00% 0.00% 0 Chunk Manager
Joseph W. Doherty Wed, 04/01/2009 - 09:29
Since your five second CPU interrupt utilization is the same as the total CPU utilization, ordinary traffic forwarding could be the cause. What processing engine are you using and what's the total volume of traffic passing through the router?
