Network Topology SSH not working.
Apr 1st, 2009
I can't get SSH to work in network topology. When I am viewing my map I right click and select ssh.. It brings up a SSH: dialogue box for a username I put the username in and hit okay...
then I get..
SSH Client not found.
ssh client configuration missing..
configure SSH client in java plugin control panel.
In java plug-in control panel in the Java Runtime Parameteres I have
-DCMMSH=E:\putty.exe
where E: is the hard drive ofcourse.
any ideas... I do get The publisher could not be verified. are you sure you want to run the software? When I just double click the putty.exe..
Any ideas?
glynncounty Wed, 04/01/2009 - 09:14
Okay. After reviewing those forums. It would appear that unless you have Campus Manager 5.1.1 you will not be able to get SSH going. I have lms 2.6 and i have the most current campus manager 4.0.12.
So guess there is nothing else that I can do?
