Unity 7.x media master recording-from a pc workgroup
Apr 1st, 2009
Hi all, I am trying to figure out a log in problem to the media master. If my pc is a member of the domain my log in works fine and I can use the media master. If my computer is a member of the workgroup it appears the login credentials are not passed correctly. Is recording from a pc in a work group supported? Unity is in its own domain. Grant access Utility solve the problem?
ahochau_2 Wed, 04/01/2009 - 10:46
You have not enabled anonymous DCOM access. thus you need to authenticate to the box in order to run the run the media master control. Re-run the perms wizard and check the box on the media master control window and the authentication boxes will go away. How ever, checking the box allows anonymous users to remotely execute code on you server.
