IPCC Express : automatic logout timer
Apr 1st, 2009
I would like to know whether there is any setting in IPCCX 4.0 by which agent which is logged into IPCCX system using either IPPA or CAD automatically logs out after a specific time? If yes, what is the default timer and how do we change the same?
Appreciate your early reply.
-> Tanmay
Anthony Holloway Wed, 04/01/2009 - 11:38
  • Purple, 4500 points or more
There is no logged in timer feature available.
You would have to build your own custom app/script to check for people logged in longer than a normal shift. But then you run the risk of terminating someone who is working a double.
