asa 5505 dsl / mtu based ssl problem
Hi everyone,
We moved our office to a different location (including our dsl conncetion). We also updated our asa from 8.0.3 to 8.0.4.
Since then, I'm having trouble opening the webportal from customers having a dedicated line.
I'm getting the certificate, can confirm it but the page won't load. When setting down the MTU size on the client everything works fine. Using a DSL or UMTS Line also works like a charm.
î've set:
mtu inside 1500
mtu outside 1492
sysopt connection tcpmss 1452
crypto ipsec df-bit clear-df inside
crypto ipsec df-bit clear-df outside
i also attached an packet trace showing tcp checksum errors while loading the page.
Anybody has an idea?
Overall Rating: 5 (1 ratings)
Julian,
You are contributing to the issue with "sysopt connection tcpmss 1452"
Change it back to the default "1380" or lower - I suggest lower I use "1300"
And the commands
AFAIK they do not apply to the SSL connections
