CSM header modification to report true source-ip
Apr 1st, 2009
I have a need to modify the Source-IP in the HTTP header to report the client and not the loadbalancer IP. I've attempted to use the method listed in the documentation, however the client IP is not being logged:
module ContentSwitchingModule 5
vlan 120 client
ip address x.x.x.68 255.255.255.192 alt x.x.x.69 255.255.255.192
gateway x.x.x.65
vlan 121 server
ip address y.y.y.100 255.255.255.248 alt y.y.y.101 255.255.255.248
route z.z.z.149 255.255.255.255 gateway y.y.y.97
route w.w.w.117 255.255.255.255 gateway y.y.y.97
route v.v.v.117 255.255.255.255 gateway y.y.y.97
natpool POOL1 y.y.y.102 y.y.y.102 netmask 255.255.255.248
map HEADER-INSERT header
insert protocol http header Source-IP header-value %is
real TESTSERV1
address z.z.z.149
no inservice
real TESTSERV2
address w.w.w.117
no inservice
real TESTSERV3
address v.v.v.117
inservice
serverfarm TESTFARM
nat server
nat client POOL1
real name TESTSERV1
inservice
real name TESTSERV2
inservice
real name TESTSERV3
inservice
policy INSERT
header-map HEADER-INSERT
serverfarm TESTFARM
vserver TESTFARM
virtual x.x.x.70 any
serverfarm TESTFARM
advertise active
persistent rebalance
slb-policy INSERT
inservice
Do I have this correct?
Syed Iftekhar Ahmed Wed, 04/01/2009 - 21:54
  • Blue, 1500 points or more
Remove the serverfarm from the vserver configuration. Since you are using a policy, the serverfarm serves as a default serverfarm.
I am sure you understand this but just wanted to make sure
You wont see source IP as "source ip" of the request. This config will ensure that your http header will include a header "Source-IP" with source ip of request as the header value.
Syed
joemarr_brodart Thu, 04/02/2009 - 06:43
Did you mean remove the serverfarm from the policy? If I remove it from the vserve, wont this break lb if I have multiple differnet serverfarms and vservs?
As for the Source-IP, I assume this means I need to modify Apache/IIS to add this header to the log entry?
Syed Iftekhar Ahmed Thu, 04/02/2009 - 14:48
I mean
vserver TESTFARM
serverfarm TESTFARM <-- is not needed
advertise active
slb-policy INSERT <-- SF is already referenced here
inservice
Syed
