IBM Informix Connect software
Answered Question
CM 6.1 Informix db ODBC
Wednesday, April 01, 2009
Guys
Does anyone have a link or a download for IBM Informix Connect software? "Not a trial version." According to the website Querytool.com it says I need the IBM Informix Connect software.
Is anyone connecting to the Informix db in CM 6.1 now?
Or
Informix Connect Runtime “I think”
Thanks, Tom
Correct Answer by lindborg about 7 years 11 months ago
I don't believe CM offers a way to do direct ODBC connections from off box - Unity Connection does this via an ODBC proxy service (which has to be enabled and turned on - if off out of the box) - CM has not equivalent I don't think. You have to go through AXL or the like to get at their data.
For Unity Connection tools on www.CiscoUnityTools.com there are links to the client ODBC drivers needed to connect via the ODBC Proxy - this is not the full Informix Connect client installation package however.
Overall Rating: 5 (1 ratings)
Correct Answer
lindborg Wed, 04/01/2009 - 13:32
