LAN Interface dropping Packetes
Apr 1st, 2009
I have two Aironet 1232 and both of them have started dropping packets today. When I ping thier IP I am losing at 50% of the packets. They are able to keep a stable wireless connection with their clients but the clients are unable to access the LAN.
I just found it odd that two access points would have the same problem on the same day. I'm monitoring my network for unusual traffic but have not found any.
I also set one of them back to factory default but I continue to have problems with the LAN side of it.
Is any one aware of a virus that could be causing this? Am I being Hacked?
Leo Laohoo Wed, 04/01/2009 - 16:21
From the WLC, can you do "sh ap eventlog ", what are the results?
What's the CPU level of each accesspoint?
pmelero75 Wed, 04/01/2009 - 16:59
CPU Usage very High - What do you think is happening?
CPU utilization for five seconds: 96%/95%; one minute: 96%; five minutes: 95%
PID Runtime(ms) Invoked uSecs
Leo Laohoo Wed, 04/01/2009 - 17:42
What's the result when you do a "sh ap eventlog "?
When you consoled into the AP, do a "dir" and see if you can find any crashinfo or r0.core file.
What is the firmware you are running on your controller?
pmelero75 Wed, 04/01/2009 - 17:47
I did not find crashinfor or ro.core files.
I'm running verions 12.3
talmadari Wed, 04/01/2009 - 21:35
I assume that u talking about autonomous AP's?!
what is the VLAN configuration on these AP's?
Try to check if there are broadcast storms or network loops?
pmelero75 Thu, 04/02/2009 - 15:24
It turns out my DC was generating WINS traffic at a unusually high level. For what ever reason that was killing the APs processor. I simply rebooted the server and the issue was resolve.
Thank you for leading down the right path.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
