password crack 501 PIX -w- 6.3(5) code
Apr 1st, 2009
isn't there a cisco tool for decrypting "user level" passwords?
thanks, kevin
Fernando_Meza Wed, 04/01/2009 - 21:26
It might be somewhere but I have not came accross one. The PIX uses a different type of encryption whihc is not so easy to crack. If you are trying to gain control to a PIX firewall and you have forgotten the credentials. You can use the password recovery procedure as per the below link
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_password_recovery09186a008009478b.shtml
I hope it helps .. please rate it if it does !!!
