RME detailed device report stuck.
Apr 1st, 2009
I've a detailed inventory job stuck in the RME Jobs.
I'm unable to delete it.
I've restarted the process without more success (dmgt stop and start).
It seems to be block somewhere.
Check my attach file for more information.
Joe Clarke Wed, 04/01/2009 - 20:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you have a 1015 process registered with Daemon Manager, you can do:
pdterm 1015
Then you should be able to delete the job. Else, you will need to contact TAC to get the procedure for removing the job from the database.
pvignaud Thu, 04/02/2009 - 10:26
The process isn't register in a pdshow command. I'll open a case but :
where the RME Jobs in Job Mgmt section are stored ? I've few JobIDs but not all are located in a pdshow command.
I've too an Inventory Collection who's running each day at noon. I delete the job and the next day, the job came back.
There are the schedule RME Jobs tasks defined ?
Thanks.
Patrick.
