Fiber optic cable check command
Answered Question
Apr 1st, 2009
I know that "show cable-diag tdr int [slot/port]" command can check 10/100/1000 etherent link. For example WS-X6748-GE-TX... etc.
But I can find any command to check gigabit only ethernet link. for example WS-X6724-SFP
Is there no command to check fiber link??
Thank you
Correct Answer by Leo Laohoo about 8 years 3 months ago
It's got nothing to do with your IOS. The command "show interface transceiver detail" will NOT work on non-DOM (Digital Optical Monitoring) modules, like the SFP. If you have a 10Gb module or the ruggedized SFP, try and this will work.
What are you trying to test on your cable?
Overall Rating: 5 (1 ratings)
Leo Laohoo Wed, 04/01/2009 - 20:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What are you trying to test on the fiberoptic?
Have you tried "show interfaces transceiver detail"?
kilsoo.choi Wed, 04/01/2009 - 22:44
I tried "show inter g3/3 tran det".
But the switch display below message.
Router#sh int g3/3 tran det
Diagnostic Monitoring Data is not available.
Could tell me why does switch display that message?
My switch' IOS version is 12.2(18)SFX5.
Correct Answer
Leo Laohoo Wed, 04/01/2009 - 22:48
  • Hall of Fame,
    2017 LAN, Wireless
kilsoo.choi Wed, 04/01/2009 - 23:16
Thanks for your answer.
I want to check a optical dBm at running switch. So I want to forecast a possiblity of optical link problem with low dBm.
Is there any way I want?
Thank you
