857 acl problem
brentsergent
My 857 ver 12.3(8r)Y14 doesn't use acl in for anything inbound from public side rather pat translations. This works for one port translation to a server on the trusted side but not for another port to the same server. When I add an inbound acl for public access outbound traffic for web doesn't work. Even with a specific acl to permit outbound ip traffic. What im trying to understand is if there is some virtual interface whereby content filtering is occuring. Note: no cbac (ip inspect) or any other acl's are working. ip virtual-assembly is applied to both private nat int and public nat int. stumped...
6 Replies 6
John Blakley
No filtering exists if you don't use an acl on your public interface and not using cbac. It's hard to tell what's going on without seeing your config, but if you have public addresses going to the same internal host, rather than specifying by port, I would do a one to one translation and then control access with an acl.
HTH,
John
HTH, John *** Please rate all useful posts ***
Agree that there shouldn't be any filtering- here's the relevant parts of the config, wanting to move to acl control but when I enable an acl outbound web traffic is blocked. You will see acl 101 allows for all traffic out. My thinking is now to debug ip nat port and see why 2222 isn't working. Can you reload acls without a restart? or once they are removed from an interface the int is clean?
interface Vlan1
ip address <###>
ip nat inside
ip virtual-reassembly
interface Vlan100
no ip address
interface Dialer0
ip address negotiated
ip access-group 101 out
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
dialer pool 1
dialer-group 1
ppp pap sent-username <###>
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static udp <###> 162 interface Dialer0 162
ip nat inside source static udp <###> 161 interface Dialer0 161
ip nat inside source static tcp <###> 2222 interface Dialer0 2222
ip nat inside source static tcp <###> 3389 interface Dialer0 3389
access-list 101 permit ip any any
Try taking the acl off completely and see if everything works. If you need an acl to block inside traffic going out, place your acl on the vlan1 interface in the inbound direction. Everything else looks "okay."
You can't "reload" acls per se. You just take them off of the interface and reapply, but that generally doesn't fix anything. =)
HTH,
John
thanks John y
our help is appreciated.
The outbound ruleset was left in place for inbound acl testing; however I get same result having no outbound acl.
This has changed my mindset to accept that there isn't filtering im not aware of going on with these 800 series routers.
thanks again
From the config excerpt that you posted, I can't see any problems. Can you post your full config minus passwords and public addresses?
HTH,
John
version 12.4
no service pad
service tcp-keepalives-in
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone
crypto pki
no ip gratuitous-arps
no ip dhcp use vrf connected
ip dhcp excluded-address
ip dhcp pool cogentlab02
network
default-router
dns-server
lease 0 4
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip domain name onesource.co.nz
ip name-server
login on-failure log
login on-success log
archive
log config
logging enable
logging size 200
notify syslog contenttype plaintext
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh source-interface Dialer0
ip ssh logging events
ip ssh version 2
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
duplex full
interface FastEthernet1
interface FastEthernet2
duplex full
speed 100
interface FastEthernet3
duplex full
speed 100
interface Vlan1
ip address
ip nat inside
interface Vlan100
no ip address
interface Dialer0
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 1
dialer-group 1
ip default-gateway
no ip forward-protocol nd
no ip forward-protocol udp domain
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.0.171.0 255.255.255.0 192.168.249.253
ip route 172.16.0.0 255.255.255.0 192.168.0.254
ip route 172.16.1.0 255.255.255.0 192.168.0.252
ip route 172.17.100.240 255.255.255.240 192.168.0.254
ip route 172.30.254.0 255.255.255.0 192.168.0.254
ip route 172.30.255.252 255.255.255.252 Dialer0
ip route 172.30.255.252 255.255.255.252 192.168.0.254
ip route 192.168.2.0 255.255.255.0 192.168.0.254
ip route 192.168.249.0 255.255.255.0 192.168.0.254
no ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source static udp 162 interface Dialer0 162
ip nat inside source static udp 161 interface Dialer0 161
ip nat inside source static tcp 2222 interface Dialer0 2222
ip nat inside source static tcp 3389 interface Dialer0 3389
logging trap debugging
logging 192.168.0.200
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.249.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 172.16.1.0 0.0.0.255
access-list 1 permit 172.16.0.0 0.0.0.255 log
access-list 1 permit 172.17.100.0 0.0.0.255
access-list 101 permit tcp any eq 443 any
access-list 101 permit tcp any eq www any
access-list 103 permit udp any eq domain any
access-list 103 permit udp any any eq domain
access-list 103 permit tcp any host 192.168.0.1 eq 22
access-list 103 permit tcp any host 192.168.0.200 eq 2222
access-list 103 permit tcp any host 192.168.0.200 eq 3389
access-list 103 permit icmp any any
access-list 103 permit ip 192.168.249.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server group
snmp-server group
snmp-server community alu RW
snmp-server trap link ietf
snmp-server location cogent lab
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 5 0
password
transport input ssh
scheduler max-task-time 5000
end
