Call Manager EXPRESS integration with AVAYA Message System
descalante2007
Does it can be possible?
I had found some basic documents to make this integration with CCM using QSIG T1/E1 links and VG248, but I just was advised the customer has CME.
Does the CME support QSIG? As VG248 is not supported by CME, VG224 can be used instead?
smalkeric
Level 6
Level 6
CME can integrate with QSIG. To enable Cisco Unified CME to interrogate a QSIG message center for the message-waiting indication (MWI) status of an IP phone extension, use the mwi qsig command in ephone-dn or ephone-dn-template configuration mode.
What about the physical level?
I understand QSIG is a subset of ISDN standards, so I must to use T1/E1 interface to integrate with Avaya system?
Yes, correct. Actually Q.931 is a subset og QSIG, not vice-versa.
