How can I do direct ip dialing?
aherraez77
Hello:
Usually I configure the dial peers with the command session target with the remote gw ip address.
there is any way to make the call using an ip from the caller endpoint?
In each call the user can dial a different ip address and I need that the gw sends the setup to that ip.
If I can not do it with ios, there is some product from cisco that it can do it?
Thanks everyone
0 Replies 0
