Warning message
Unity Express Upgrade
Apr 2nd, 2009
I'm trying to upgrade my Unity Express on my 2801, at the moment I'm using 2.1 and I would like to upgrade to 3.1
I have been informed that it would be easier if I did a clean install rather than follow an upgrade path.
Can somebody help me with my issue please because when I try to install I get the following:
ERROR: Invalid package. Please verify if this is a valid package file.
This is my command:
software install clean cue-vm-en_GB-langpack.nm-aim.3.0.1.prt1
Is that the incorrect file that I have, if so what is the correct package name I require?
My current Installed Packages:
- Installer 2.1.3
- Bootloader (Primary) 2.1.2
- Infrastructure 2.1.3
- Global 2.1.3
- GPL Infrastructure 2.1.3
- Voice Mail 2.1.3
- Bootloader (Secondary) 2.1.2
- Core 2.1.3
- Auto Attendant 2.1.3
Installed Languages:
- British English 2.1.3
Martyn
Overall Rating: 5 (1 ratings)
Rob Huffman Thu, 04/02/2009 - 09:01
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Martyn,
It sounds like you only have the Language File. You would be looking for these "full" Packages;
cue-vm-full-k9.nm-aim.3.1.2.prt1
Package payload containing all data and executable files associated with a Cisco Unity Express with VoiceMail application full installation on the AIM-CUE, NM-CUE, and NM-CUE-EC service modules. 3.1.2 10-MAR-2008 82129808
cue-vm-installer-k9.nm-aim.3.1.2.prt1
Package payload containing all data and executable files for the installer subsystem associated with the Cisco Unity Express with VoiceMail application on the AIM-CUE, NM-CUE, and NM-CUE-EC service modules.
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-312-nm-aim
Hope this helps!
Rob
