Warning message
QOS on non routed vlans
Apr 2nd, 2009
We have a trunk link which we use to connect two sites. We have numerous non routed vlans which are running across the trunk. I need to create a qos policy which will give the traffic from one particular vlan priority over everything else. I'm not sure what method I should be using to classify the traffic. Should I use mac-addresses rather than ip addresses as the traffic will be switched or is there a way to classify a particular vlan. Any help greatly appreciated.
Jon Marshall Thu, 04/02/2009 - 07:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Darren
What switch type are you using ?
Jon
