Management interface
John Blakley
I've configured the management interface on our ASA 5550. The address is 192.168.254.5 and it's next hop is .1 (vlan 254 on 3750).
I can ping the management interface fine from my laptop (10.128.100.75), but I can't telnet to the device on the management interface and it gives the following error:
%ASA-6-110003: Routing failed to locate next hop for TCP from management:192.168.254.5/23 to management:John-Blakley/2223
I can't add the route as "route management 10.128.100.0 255.255.255.0 192.168.254.1" because it says that it overlaps with an existing route. The 10.128.100.0 subnet will be exiting out of the inside interface.
What have I missed?
John
HTH, John *** Please rate all useful posts ***
Jon Marshall
John
You could try adding a specific route for your laptop out of the management interface but then that would break your Internet access from your laptop.
Problem is telnet is stateful TCP - so the packet enters the ASA on the management interface but then the ASA cannot find a route back to your laptop via that same interface so it drops it.
Jon
Jon Marshall
John
Jon
Jon,
I figured out that I won't be able to do that. I guess having a management interface on a different subnet means that you should have a system on that same subnet dedicated for that purpose alone.
Thanks!
John
maldavis3697
I'm not sure if this is workable in your situation but if your IT department works on a particular subnet that's smaller than the 10.128.100.0/24 subnet you could put that in to exit the management interface.
We had a similar problem with setting up our management interface on our ASA recently. We have a route through the inside interface that was for 10.0.0.0/8 but we were also able to put in a smaller subnet (10.10.5.0/28) to exit the management interface just for the IT department. It might be a good idea to define a route for a smaller subnet to the IT department anyways as a security precaution.
This worked for us and then traffic that went in the management interface knew how to get back out. I didn't get the exact error you got but then I didn't try to telnet to the ASA. Let me know if this works for you. :)
