VPN 3002 tracert
Apr 2nd, 2009
I have a VPN 3002 configured for network extension mode connecting to an ASA. The connection works fine. But we have an application that use tracert to verify the client is accessable (SMS remote control) before you can connect. The problem is that when i tracert to a client that is behind the 3002 device
I get a request timed out * hop. Then it completes on the 3rd.
Is this normal behavior for a VPN 3002? I have other remote users using the Cisco VPN client and the traces work fine.
How can get it to trace with no requests timed out?
michaelbrunton Wed, 04/08/2009 - 07:23
The device that is connecting (VPN) to the ASA is a VPN 3002 hardware client. I have no options on the client to create a filter rule.
