Maxium calls on Analog devices CCM v.7
Apr 2nd, 2009
I know this is probably a silly question but I would like to verify. Devices such as ATAs and VG248s that converts calls to analog, I've notice have only maximum call of 2. Is there a way around this or another way I have analog maximum calls set to 4?
Brandon Buffin Fri, 04/03/2009 - 08:01
  • Purple, 4500 points or more
The help document for the directory number settings page says:
"The default specifies 4. If the phone does not allow multiple calls for each line, the default specifies 2."
Analog devices do not support multiple calls per line. There is no way around this limitation to my knowledge.
Hope this helps.
Brandon
