Peer Firmware Sharing or Load Server in CM 5.1(3)
Apr 2nd, 2009
Someone have used some of these feature?
I'm planning an CM upgrade in a customer with 4,000 phones distributed over 140 sites and many of them have low speed links (< 512 kbps). So my ideas are:
I) Enable Peer Firmware Sharing, but I don't know if this work in CM 5.1(3), I think that this setting must be enabled before CM upgrade.
II) Load the new firmware (mainly for SIP firmwares) in gateways flash memory, and use them as 'Load Server'. But again, I think that I must enable this feature before CM upgrade.
Best Regards,
Fabio Funaki
