Catalyst 3750 monitor
Apr 2nd, 2009
set up monitor of an access port connected to a router. Only seeing traffic coming toward the switch from the router even though specified both. Any ideas...thx
Yudong Wu Thu, 04/02/2009 - 15:14
Can you try the following?
1. remove all SPAN config and then add it back
2. try span only tx direction to see if it works.
By the way, is it a single 3750 switch or a stack
