PLAR on an MGCP controlled VG224 Gateway
Answered Question
Apr 2nd, 2009
Hello
Is it possible to configure PLAR on a port on a VG224 controlled gateway to call a DN? if so how would you go about configuring it.
thank you
Correct Answer by Michael Owuor about 7 years 11 months ago
Hi Dean,
Is is possible. Here's an example of how to do it.
1. Create a partition called "Hotline".
2. Create a calling search space called "Hotline-CSS".
3. Move the partition "Hotline" into the "Hotline-CSS" calling search space.
4. Create a translation pattern. Leave the pattern itself blank, select "Hotline" as partition, and specify a calling search space that contains the number that the PLAR phone needs to dial. Enter the destination number in the "Called Party Transformation Mask" field.
5. From the configuration page of the gateway, select the port connected to the analog phone that will serve as a PLAR phone.
6. Set the "Calling Search Space" field to "Hotline-CSS" for this port.
7. Reset the MGCP member.
I hope this helps.
Michael.
Overall Rating: 5 (2 ratings)
Correct Answer
Michael Owuor Thu, 04/02/2009 - 08:55
  • Cisco Employee,
Hi Dean,
I hope this helps.
Michael.
deanhoy Fri, 04/03/2009 - 07:43
thank you for the reply. I will try this and update you.
Regard
Dean.
timspencer_cbts Thu, 05/07/2015 - 09:12
also note -  (as this is confusing)  You do NOT put an DN on the extension.  You go to the port, add the CSS.  No DN is needed.
