Password Recovery for PIX 506E - Very Urgent
smohanasundaram
i am using PIX 506E with software ver 4.3.i try to recover my password its fails.
Please go through the following .
this steps followed during password reset
monitor>interface 1
0: i8255X @ PCI(bus:0 dev:13 irq:10)
1: i8255X @ PCI(bus:0 dev:14 irq:7 )
Using 1: i82559 @ PCI(bus:0 dev:14 irq:7), MAC: 0050.54ff.82b9
monitor>address 1.2.3.4
address 1.2.3.4
monitor>server 1.2.3.5
server 1.2.3.5
monitor>file nppix.bin
file nppix.bin
monitor>ping 1.2.3.5
Sending 5, 100-byte 0xf8d3 ICMP Echoes to 1.2.3.5, timeout is 4 seconds:
Success rate is 100 percent (5/5)
monitor>tftp
tftp nppix.bin@1.2.3.5 via 1.2.3.4...................................
Received 73728 bytes
Then pix automatically hangs
Please help me to resolve this issue
Thanks in advance
Mohan sundaram.S
John Blakley
Is this on just one computer that you've tried to tftp the file from? Is there a switch between you and the pix, or are you connected directly into the pix?
The syntax is correct.
HTH,
John
HTH, John *** Please rate all useful posts ***
