Delete SIP image on 7912--- sip image lock
Apr 2nd, 2009
Hi Guys,
Is there a way to delete the SIP image on 7912. Tried to reset the phone to the factory default, but it does not work. Pointed the phone to download a new image,but still does not work.
The main goal is to have the phone works with H323.
Any ideas?
Crazy
Anonymous (not verified) Wed, 04/08/2009 - 07:10
Try to do the manual procedure:
Disconnect the phone.
Manually delete the phone from the CCM
Manually add new phones with the right protocol
Connect the phone back, reset the phone.
Paolo Bevilacqua Wed, 04/08/2009 - 07:12
  • Hall of Fame,
    Founding Member
Are you using the binary config generator in the correct way ? You might need to bump the version number field in order to convince the phone to load the new image.
