Mobile Connect with E911
Apr 2nd, 2009
We have E911 service setup on our PRI. When we try to setup Mobile Connect the caller ID that is presented to the remote destination is the main billing number of the PRI. The carrier is overwritting the caller id because it is not in the DID range for that PRI. The carrier (AT&T) says that they cannot configure this any other way. With E911 they need to check caller id against the DID range and cannot pass any other caller id. Without E911 they can pass any caller id and it will work. Is there any way to get the original caller id in this situation without having to disable E911?
