Have forwarded phone call return to unity
Overall Rating: 4 (1 ratings)
Jaime Valencia Thu, 04/02/2009 - 11:12
  • Cisco Employee,
  • Hall of Fame,
    2011
if you set the behavior to attempt transfer to and choose yes, ring subscriber at this extension doing a supervised transfer if the number of rings is less that the amount your mobile VMs takes to answer it will go back to unity's VM
java
if this helps, please rate
